FSAE EV Rules 2014 Questions
Dear FSAEe colleagues,
Dear Tobias,
I have two questions so far on this year rules improvements. :-)
EV3.4.8: "[...] The contained energy of a stack is calculated by multiplying the maximum stack voltage with the nominal capacity of the used cell(s)."
- Why? Usually, energy is measured with nominal voltage. Maybe it refers to the way the 6 and 12 MJ limits have been decided?
EV8.3.3: "The charger must incorporate an interlock such that the connectors only become live if is correctly connected to the accumulator."
- We are using Brusa NLG5x3 chargers. They automatically detects when the output is disconnected, and it quickly (<0.1 sec) disables the HV output. The detection is made, I think, when it realizes that the current equals zero. Would this software interlock comply with the rule?
Kind regards,
P.S. As some of you might have notice, Tobias Michael decided to start a blog.
P.S. #2: Is there a difference between a molten salt and a thermal battery?
EV2.1.2 Motor Rule Question
Hello everybody, hello Tobias,
I have a questions concerning the following rule:
EV2.1.2 Motors must be contained within a structural casing where the thickness is at least 3.0 mm (0.120 inch). The casing must use an Aluminum Alloy of at least 6061-T6 grade or better if a casing thickness of 3.0mm is used. If lower grade alloys are used then the material must be thicker to provide an equivalent strength.
Note: Use of a higher grade alloy does not enable a reduced thickness to be used.
At this point, I am not sure whether the rule refers to an additional housing or the motor case itself. (Although I must admit, I have yet to come up with a clear meaning for ‚structural casing‘ - perhaps this is crystal clear to native speakers…)
In Tobias Michaels blog, he states:
EV2.1.2:
Change: A minimum strength/thickness requirement for motor housings has been added.
Impact: Many teams may have to re-design their motor housings or at least check whether it fulfils the new requirements. This rule has been added due to lots of discussions this year at scrutineering about the necessary thickness of motor housings.
So, this sound promising, but it is not official, so...
We employ a rather sturdy motor out of a series-production vehicle that has a casing that might fulfill the material and thickness requirements. Would this be enough or is an additional casing mandatory?
In case the motor case is enough, what kind of documentation would be required and where would we put is? (SES, I assume)
Concerning the geometry of the case, if necessary: Since the new rule is akin to the scatter shield rule T8.4.4, we have been wondering if some kind of cylindrical case with open ends would be enough to comply with the rule (and contain exploding motors...) If not, how wide can openings for ventilation and such be and where should or could they be placed?
Thanks alot!
Kind regards,
Tobias R
Combined University Racing Berlin (CURB) - Germany
Motors rule -> T-Rule and FAQ?
Hello Hugues,
thank you for your reply.
I find your argument very logical so at this point I will tell my guys to proceed without the extra case until I hear anything different. It is a risk I am willing to take.
You also mention T8.4.6 and a FAQ. The rule is about finger protection and I am yet to find the mentioned FAQ. Can you elaborate please? Thanks alot!
Kind regards,
Tobias R
