Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Aero track testing
    Daryl, I'm quite sure that MANY of the aero teams (I know at lest one) have used the "coast down" method to determine drag, and shock sensors to determine (sprung) aero DF. But as Menisk already mentioned the DF part won't apply to unsprung or "half-sprung" aero... Jakob, if I were you I would be extremely cautious about increased unsprung mass and extra stiffness added to your suspension from the undertray (on some modes more than others). Of course this could be tackled with some innovative design. It might worth it, or maybe not, it's up to you to decide. I think some American team has run an unsprung undertray some years ago, but abandoned it in favor of a sprung one.
    Try using pancake load cells on the mounts at the uprights. Really, all the other methods here aren't that great. I wouldn't really trust wind tunnels either, unless they were really big.
    Mike Cook
    It's an engineering competition, not an over-engineering competition!
    <BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Jaaps:
    My team is for the first time starting aero effects on our car this year.
    ... I don't think that this method alone would be sufficient to impress the judges... </div></BLOCKQUOTE>
    Jakob,
    1. Don't try to "impress the judges". You have 600+ points on offer from good aero, and only 150 from Design. Go for the 600+.
    2. For testing/development, Steven above has the right idea. Keep driving in big circles until you are pulling 3G lateral. You only need a stopwatch to measure this. Put simply, with good aero your times should drop by 30%.
    3. For good understanding of the underbody flows use wool-tufts and one of those small cameras (mounted downstream so as not to mess up what it is looking at). Harry's suggestion of pressure tappings is also good. A clear (eg. pvc) tube with water + food colouring in it, set up as a Pitot-Static tube, is a simple way to start. Then compare with CFD, and see how wrong it is!
    4. For good downforce I suggest you don't simply copy the usual gradually rising "diffuser". Instead have approximately equal cross-sectional area of the "tunnels", front to rear, with low front and side splitters, and a curved flap or two just above/behind the rear of the tunnels. These flaps will "drive" the underbody much more effectively than a simple diffuser.
    5. The more iterations you go through, the better. So start with plywood, Maxbond, tek-screws, plasticine, duct tape, fencing wire, whatever. You can make the last iteration pretty to "impress the judges"...
    Aug 2011
    Brisbane, Australia
    132
    Just on Z's 5th point. I have no doubt plenty of your QUT guys have seen that crazy homebrew car with kart wheels that runs at mount cotton and goes awfully fucking fast.
    Modena, Italy
    363
    Jaaps,
    is it possible to mount the undertray to the chassis just for a straight line test?
    I was planning on doing the circular runs under a stopwatch, also if we can find a big enough patch of earth, set up a endurance track and do lap times.
    and also to do flow visualisation, also the wool tufts with a GoPro strapped to the back, lucky we have one or two guys on the team which have one.
    I was not trying to 'impress' the judges, just to back our cfd data with accurate results.
    I haven't been to Mt Cotton, I'll be sure to ask the boys about it
    @Timo,
    Nah our whole design relies on the undertray being unsprung.
    Thanks for all the suggestions. Really appreciate it all
  7. #17
    Modena, Italy
    363
    I understand it needs to be unsprung in a dynamic track condition, but for a straight line constant velocity test, as long as it in the right location, it doesnt matter if its mounted to the chassis or upright.
    The problem with skidpad and endurance laps is that you introduce soo many other variables including driver and tyre temperature. Both of these are eliminated in a constant velocity test.
    If you really must go down the stopwatch route, Id forget the endurance track and do either a constant radius (at two radiuses small and large) or a constant velocity ramp steer at two speeds (maybe 40 and 80km/h). As many repititions as you can with and without the aero to make sure the tyre temps and degradation are not stuffing your results
    Tim
