I am stuck in a debate with a team member as to how to FEA our frame. We are convinced that we need to physically test our finished frame after construction to verify the FEA, but the question is how? I understand that some teams just bolt one end of the frame to the table and twist the other end and measure the force and deflection. My fellow team member is bringing up the point that the frame is not actually subjected to that type of loading in the driving scenario, but instead, the loading on the frame comes in through the suspension mounting points. Therefore, it is stated that the FEA model needs to be loaded through the suspension mounts to represent what is actually hapening in the competition. Not too much of a problem in FEA, but how do you do this for the physical frame testing? You can't really make a jig to bolt the frame to through the suspension mounts as that would constrain it unlike it is in reality. Any ideas??? I personally think that too much is being read into it. What does ebverybody else think? How has everybody else done it in the past? Thanks!!
