Do we need to deactivate the shut down circuits in case of accumulator voltage less than 60 volt? As in this case TSAL(Tractive System Active Light) will turn off.
This is a clear question for the rules committee - I imagine that they didn't envision this being a possibility.
Out of curiosity what is your planned min/nominal/max accumulator voltage?
Penn Electric Racing
Sharan,
this is clearly defined by the rules, you should read them some more times!
In this case, you have to look for the word "OR" in rule EV4.12.1 and you will find out that the contactors can stay closed because the TSAL will not turn off - if rules compliant.
Cheers,
Sebastian
