how do i select the right tire for my fsae car? what are the different criterias to look into before selecting one?![]()
If you have only one line to ask. My answer must be: Take a Hoosier. If your car is < 200kg, take the 10inch, if it is above, take the 13 inch.
Alumnus
AMZ Racing
ETH Zürich
2010-2011: Suspension
2012: Aerodynamics
2013: Technical Lead
I recommend selecting the same as the left tire. Same with wheel but turn around because it rotates the other way.
You can select any tire allowed by the rules.
For the international rules, see T6.3 for info on wheels (which defines your size constraints), and T6.4 for further tire rules. If you are at a competition where the international rules aren't used, then I have no idea.
Beyond that the sky is the limit. Tires have been sourced from Hoosier, Avon, Goodyear (in the past), Michelin, Continental and Dunlop if I recall correctly. The Hoosiers are pretty much the standard for teams these days.
As for selection, you should look into this thread:
http://www.fsae.com/forums/showthrea...for-car-design
University of Waterloo Formula Motorsports Alumni
http://www.uwfsae.ca/
My views, thoughts and wording do not reflect those of Carleton University in any way, shape or form.
"The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather a lack of will." - Vince Lombardi
CU FS Ravens Racing - Powertrain Dev. 2014
CU FS Ravens Racing - Team Lead/Tooling 2013/2014
CU FSAE Ravens Racing (Volunteer Team) - Team Lead/Structures/Manufacturing 2012/2013
CU FSAE Ravens Racing (Volunteer Team) - Team Lead 2011/2012
