Jay and MCoach,
Given that FSAE students are known throughout the universe as the "Masters of Floppy Linkages", I must assume that you are kidding with your above comments. This assumption supported by Jay's humorous question "Do you intend to hammer the locating pin in so it's a nice fit with zero compliance?", and MCoach's suggestion that my brake system has "two 30" ... [pull-]rods" when quite clearly they are closer to 10" in length. Also MC's acknowledgement of his prior mastery of floppiness.
Bill,
You suggest that students, such as above, should get busy FEMing when they want to determine which linkages are floppier (or stiffer?) than others. Sadly, I suspect that it is the FEM itself that is the root cause of this problem.
Two generations ago all students were given "calculators", and now hardly any can do simple sums.
One generation ago all students were given word-processors with "spell-checkers", and now hardly any can spell simple words.
Today all engineering students have access to structural-analysis programs (eg. FEM), and now hardly any can analyse simple structures.
The problem seems to be that the young-engineer thinks that their job is simply to give an "executive level" description of the structure (ie. its rough topology), and the computer-minions will then go away and optimise it. Unfortunately, not even the cleverest computer-minion can turn a sow's ear into a silk purse, or make the major topological changes needed to turn a bad structure into a good one.
(Edit: And since the young-engineer has lost the ability to analyse simple structural topologies, they cannot distinguish the good ones from the bad ones. So we all end up with highly optimised sow's ears...)
Goost,
Thanks for the reference. I will look it up. Given that it is 1904, it should be good! :)
(Edit: The example shows that efficient cantilever beams are NOT triangular structures, as sometimes assumed, but rather are somewhat fatter in the middle...)
Finally, any students pondering the above issue of "stiffness of brake-linkages" might compare the FBDs I mentioned in previous post with those of an "almost vertical M/Cs" linkage. Keep in mind that my last sketch has the "pedal motion-ratio" at about 2:1 (foot : pullrod motions), whereas most FSAE brakes are typically at higher ratios (roughly 3:1 -> 5+:1).
Then explain how a linkage that converts the driver's NECESSARILY ~horizontal foot-force, of, say, 2 kN maximum, into TWO almost vertical forces of 6 -> 10 kN, can ever be more structurally efficient than a linkage that keeps all forces close to in-line, and at low magnitude (ie. with 2 kN foot-force my linkage has each pullrod at 2 kN tension, and the pedal-tray longitudinal member at 2 kN compression, with negligible chassis stresses/strains forward of FRH, etc...).
PLEASE SHOW ALL FBDS!!!
Or, to put it another way, I will happily wager your first year of real wages that my pedal-tray is stiffer, stronger, and lighter than yours! :)
