Quote:
Originally posted by Z:
Harry,
You ask, "In a beam suspension like the one described here, why would anyone want any stiff mode?"
For circuit racing a lowest possible CG is beneficial. So it is good to have all the heavy bits close to the ground at all times (so not bouncing upwards over crests, etc.). Formula cars have most of the heavy bits spread along the centreline of the car, so it is beneficial to have stiff heave and pitch modes that "lock" the centreline down low (with, say, +/- 5mm of highly damped soft motion to suppress bouncing on the tyres)....
...You say, "you can achieve a soft twist mode (while having harder pitch and roll modes) by making a chassis torsionally flexible...."
And, indeed, this was the way it was done in the early days of motorsport. Prior to about 1930 the production chassis were deliberately softened when they went racing, by removal of crossmembers. However, this required the right sort of engine mounts, etc., to get the right LLTD (eg. 2 bellhousing mounts at mid-chassis, and only 1 engine nose mount). Also the torsional chassis spring was undamped, except for "inertial damping" from loosely mounted fuel tank, driver, etc. A stiff chassis with damped twist-soft suspension works better....
Thanks for the input Z! So, to my understanding you want a fairly stiff pitch/heave mode... You can achieve that with a heave/pitch spring and damper for each beam, mounted under the chassis and activated via bellcrank through the suspension vertical movement (bellcrank mounts at the peg n' slot position, so not activated during roll) and using very soft springs/dampers for all other modes. I still think a "soft" chassis as a good idea though, although "undampened", mainly because of the need of only a few mounting points as explained in my earlier post; you can just use the chassis as a part holder, cutting off significant weight. Or you can just use a longitudinal z-bar configuration!
