5 Attachment(s)
Plotting Solid Axle Roll & Bump 2D
Well the stubborn old man is back with some preliminary drawings for plotting body roll and heave WRT an assumed fixed solid rear axle. i.e The use of descriptive geometry from the 'old days'.
What follows are pictures that I hope are mostly self explanatory.
Assumptions:
The axle is fixed in space and acts as the 'frame' while the body points are moved about it.
In the initial layout all links are co-planer with the knowledge that as soon as movement takes place they will not be.
Right from the start the very first problem I encountered was how to rotate the body about the axle, i.e. what frame of reference should I use?
Right or wrong I have chosen, for pure roll, to rotate the body around a horizontal line connecting the body spring/damper mounting locations. Due to the lateral restraint of the panhard link this will require a rotation and an associated translation of the body WRT the solid axle. Again your input on how correct or incorrect this might be would be appreciated.
Some pictures to go by:
Attachment 309Attachment 310Attachment 311Attachment 312Attachment 313
Looks like I will need to add a second reply????
