Panhard Bar Lateral Location Question
I am new to the fsae forum and have found a wealth of information here.
To clarify, I am not involved in fsae as a participant, judge or consultant.
I am a Tool and Model designer in industry by profession who spends his free time working on suspension analysis and tuning for lower level oval track race teams in the northeastern region of the United States.
I have been perplexed for quite some time on one particular point of the classical or the static analysis of a live beam axle suspension in common use in the arena I am working in and was hoping someone on this forum may enlighten me.
The problem:
A race car with beam axle suspensions both front and rear.
The main sticking point is the analysis of the live rear axle laterally restrained by a very short (approx. 18 in.) panhard bar offset to the right of the vehicle centerline as viewed from the rear. The panhard bar attaches to the axle just to the right of the axles centerline and to the sprung body just inside the right rear wheel as viewed from the rear. The overall height of the bar is adjustable relative to the axle centerline or ground as you prefer. The bars angularity is cockpit adjustable by the driver while the car is in motion. If we assume the bar to be set level at axle centerline height the range of adjustability is 10 degrees up from axle to chassis to 10 degrees down from axle centerline to chassis as viewed from the rear. The adjustment takes place at the chassis mount of the panhard bar via a vertical 'lead screw' and captive block assembly.
The remaining rear axle degrees of restraint are two parallel trailing links mounted solidly to the rear axle below axle centerline height (approx. 6 in.). The final restraint needed is for axle housing rotation about the y-axis which controlled by a torque arm from the live axle center section (gear housing) to a linear bearing 'sled' with large heim joint being used to attach the torque arm to the chassis i.e. one degree of restraint of the arm rotation about the lateral axle centerline.
The constraints in this form of racing:
There is no data acquisition.
There is no tire data.
The track surface may be pavement or dirt.
There is so little testing time it might as well be considered negligible.
There is no practice time to speak of.
You are left with driver feedback, observation, and possible video and thought to analyze possible setup changes.
My approach to date has been a simplistic 'classical' roll center based model to evaluate front and rear wheel pair loads to have a look at what limit behavior might be at assumed steady state lateral and longitudinal acceleration levels i.e. make spring changes or suspension link geometry changes (IC position changes) assume a 'g' level and calculate (spreadsheet) the front and rear tire pair loads.
The problem I have had with the 'roll center', 'shear point', control point type of analysis, name your favorite author here, IS the location of that point with the short offset panhard bar with angularity described above.
All of the classic texts I have (RCVD, Dixon, Olley etc.) say that with a basically planer linkage as I have described is that the roll center (for lack of a better term) is located where the rear axles axis of rotation as defined by the axles locational linkage pierces the lateral rear axle wheel pairs vertical plane. For the linkage I describe the rear 'control point' is always taken where the panhard bar crosses the vehicle centerline plane.
I see no kinematic nor force based reason for this to be the case and as Dixon points out the rear axles axis of rotation is a piece of engineering fiction useful in locating the notional roll center or force coupling point.
Well, the panhard bar does not cross the vehicle centerline in this case, what to do?
Consult Mark Ortiz.
In Mr. Ortiz's view the roll center can be located in this situation by one of two methods. The first he describes as the simple method of finding the intersection of the panhard bars centerline with either the vehicles centerline or longitudinal CG center plane if the car is not symmetrical and to neglect the internal jacking force and use that point as the roll center. The second he describes as the more rigorous method and uses the panhard bars mid-point to fix the roll center height but also says to include the internal jacking force caused by axle to chassis bar angularity in your calculations and to make the mid-point of the panhard bar the point for this jacking forces vertical point of application.
I have a great deal of respect for Mr. Ortiz's openness in answering any and all questions and agree with much of what he has written about asymmetric race cars but again I can find no kinematic or statics (force based) reason that makes the panhard bar mid-point any more 'special' then any other point.
When looking at this problem from a 2D statics point of view you come to realize that the panhard bar is simply a two force link attaching the beam axle to the body and if you free body diagram the body then the panhard bar force line of action 'on the body' is simply the bars angle and you could decompose that force anywhere along that line of action. (Yes, a Z n-line) So no point is 'special' from this point of view.
Two questions to the forum if I may:
1. In the situation as described where would you take the roll center height for a classical treatment and more importantly why?
2. What would be a better approach to getting a high level view of the effects of the short panhard bars position and angularity with respect to wheel pair loading with an assumed steady state lateral loading?
As one last point of observation I have worked with six different drivers two of which have been multi-time champions in this form of racing and only one of the six can describe the effects he feels when he has adjusted the bar past the point of a positive effect.
Thank you,
Ralph
