Quote:
Originally posted by Dunk Mckay:
I'm back with another challenge for your "aero-above-all" concept, Z.
You say suspension should be soft, and it must have 1inch of travel. But with this, even over small bumps, or light breaking and acceleration, you're going to have chassis ride height changes. This means changes in height of the BJs, effectively the beams and therefore wings are going to rotate about the wheels axes, meaning the aero effect is going to fluctuate. Not as much, perhaps, as a fully sprung wings, but enough so that to avoid the risk of stalling you'll have to reduce your peak available downforce somewhat.
This of course is not a problem if you go for the more complicated single "undertray" concept, but for the twin beam-wing it does reduce it's ...potency.
From what I can tell from his drawings, the beam-wing concept has no ability to pitch (except for flex in the beams).
