Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: 2012 Structural Equivalency Sheet (SES)
  1. #21
    ^^ the SES is already filled out with the appropriate numbers for steel. You 'should' be able to just fill out the first two sheets per the hints on fsaeonline.com if you just have a basic steel frame.
    Daryl
  2. #22
    The lamination's inner and outer skin must be the same. But we designed outer skin thicker than inner. Than we fill the SES with some deviation.
    HIT Racing Team 2009-2010 Team Leader
    HIT Racing Team 2010-2012 Technical Director
    Harbin Institute of Technology at WeiHai
  3. #23
    And we found more mistakes in V12. In the Mhoop Brace Spt tab, the E26 cell about tubes' EI, has the wrong formula, quoting C column instead of E column. And also tab of Front Hoop Bracing, Front Bulkhead, Shoulder Harness Bar Equivalency.
