Is anybody else out there just as confused with the new SES spreadsheet as me? Most of it really straightforward and just plug-and-chug.
Where I'm getting confused though is where you input the "Number of Tubes". For instance, on the "Front Hoop Bracing" sheet, the default number of tubes is 1, which I'm assuming is meant to be when viewing in side view. However, my Front Hoop Bracing consists of a "bent" tube, with a triangulating tube back to the Front Roll Hoop. So does this mean I now have 3 tubes? Or 2? The spreadsheet seems to multiply the A_cross by the number of tubes for the EI calculations. But this does not seem correct at all, and I'm confused as to how I should represet my specific layout in the sheet.
Also, default "Number of Tubes" for the Side Impact Structure is 3 (1 on top, 1 on bottom, 1 middle triangulating). However, the bottom tube on my frame is bent, so the triangulating tube is essentially 2 tubes in a "V" shape. Is the middle triangulating tube(s) simply represented as 1 tube?
I understand the reasoning behind moving to something like this, as it is indeed more thorough and means less work for the organizers, but it seems like there should be a more thorough "How To" sheet, due to the unfamiliarity from all the teams, especially newer teams.
I'd love to here some input.
