Few more bits to be added.
Not been easy with the workshop move and all the building work going on.
Nice!! It looks like we have a very similar space frame structure!!
We are moving build room too... A few things are not quite ready yet, what a nightmare!!
Harry Cheung
Retired Testing Manager/Steering/Suspension/Electrical Designer of
Team Bath Racing 2008
My Flickr | [URL=http://www.miniharry.co.uk]My Webspace
The Front Bulkhead must be supported back to the Front Roll Hoop by a minimum
of three (3) Frame Members on each side of the vehicle with one at the top (within
50.8 mm (2 inches) of its top-most surface), one (1) at the bottom, and one (1) as a
diagonal brace to provide triangulation.
The triangulation must be node-to-node, with triangles being formed by the Front
Bulkhead, the diagonal and one of the other two required Front Bulkhead Support
Frame Members.
I understand this rule as there has to be at least a diagonal brace running node to node from the lower frame member bulkhead joint to within 2in of the top of the front roll hoop. Or visa versa.
I might be wrong though, but we got pulled up on this at last years comp.
chassis!
That will be 3 of us with simular chassis then!
The front is finished now,(missing a few bars in this pic) i'll put a picture up when i get back to uni.
Also were be moving rooms after crimbo to a room just behind this pic, but hey ours has a sea view!
I believe the rules committee is okay with it if it is well triangulated. Last year, there was a xls file from them showing about 30 cases that would or would not work.
as spaceframes go I think they are all very distinguishable.
The xls file that Mike mentioned:
http://www.sae.org/forums/formula/dispatch.cgi/rules/sh...ngulation%20Drgs.xls
From here:
http://www.sae.org/forums/formula/dispatch.cgi/rules/do....6.2%20Triangulation
I'll get some shots up when ours comes back from getting the exhaust :P
Triumph Motorcycles
Chassis Design Engineer
FSAE '05-08 UBRacing
2008 Technical Director and Sprint/Endurance Driver
2007 Powertrain Team Leader and Sprint/Endurance Driver
Ours so far, welderguy is 2m tall
Pontus Fyhr - Lund University Formula Engineering alumn/assistant FA
Seems to have turned into a progress report post so...
beginning of the semester but shows our design and mock-ups.
Progress as of about a month and 1/2 ago. We now have all a arms done the steering rack/column,shocks/rockers are mounted. Most of the parts are turned. Running car for testing next month!
Sorry for the low qual. cell phone pictures it's what I had available.
Steve
