Hi all,
I want to use 2 ACBB in rear wheel assembly. I am thinking of using 2 Angular contact bearings of ID 60 mm and OD 85 mm in Tandem arrangement since I am having radial load on each bearing 1500 N and Wheel will have 2500 N axial load (Assuming Lateral Force will act in both directions during different Steering conditions). I want to Preload these both bearings by introducing Spacer ring (Which will be part of Aluminium upright itself). How should I decide the width and Inner diameter of this Spacer ring?
Should I just apply Preload force on spacer ring surface to check shear stresses or is there any other method to find the width ?
Thanks in advance
