Hello,
We just got our car running last weekend and we are trying to work all of the bugs out of the car before we leave for competition. I am running into a very strange situation. When I rev the engine to 10,000 RPM, the entire car shuts down electrically for a very brief moment, and then comes on immediately once the RPM's decrease. The engine will not rev above 10,000 RPM. It is as though there is a rev limiter acting on the engine. I have checked our rev limiter on our MSD (DIS-4) and our ECU (Autronic SM-2) and they are both set for 12,000 RPM. But even if it were a rev limiter, it would not cut power to the entire car. I have tried installing 2 separate MSD's. I have tried 2 separate ECU's. I have the engine block grounded with a ground strap. I thought I might be pulling too much electrical power with all of our electronics, including 2 fans, fuel pump, wide band O2, gauges, etc. so I disconnected everything except what is necessary to run the motor thinking that when the engine speed increases, it requires more power to run so I should minimize power consumption, and it still does it. This one has me stumped. The car runs great up until 10,000 RPM, but after that it backfires and cuts out and comes back on once you let of the gas to decrease the revs. It is a completely stock 2001 Honda CBR600 F4i. We are running the stock cam and crank sensors.
This is the same wiring system we have been using for years (meaning I make the same wiring harness every year), and I have never had a problem like this. Tomorrow i will closely examine the wiring harness to make sure everything is tight and there are no shorts or pinched wires.
Does anyone have any idea what might cause this?
Thanks,
Matt
