Pi Research C-Dash with Momo Mod/11 steering wheel. The C-Dash is designed to replace the normal set of analogue instruments in a vehicle. The C-dash uses a 7-segment LED display which can be used to display values directly from sensors or from a Pi System. The C-dash also has a number of individual bright LEDs which can be used as alarms and gear change lights. The C-dash is controlled by two remote buttons, which are used to set parameters and acknowledge alarms. The C-dash kit comprises of a C-dash dashboard unit, Momo Mod/11 steering wheel, sensor loom, display loom, button kit, temperature sensor, pressure sensor, RPM sensor. Plug-in additions to the C-dash can upgraded the C-dash to be used to give lap times and to allow it to be used as a data logger.
Price: POA
