From information I received from Pace, they don't advise running their compact C pumps at speeds higher than 6500 rpm. Pump will be used on an F4i motor. I was planning on driving the pump with the crank shaft (where the stock water pump is), as it seems many teams do. Have any teams had problems running their Pace pumps at higher speeds than 6500 rpm? Or, are you gearing it down to run at a lower speed? If it's geared down, it doesn't seem like it will have a high enough flow rate capacity.
