Results 1 to 4 of 4
Thread: Fastener Installation in Cost Report
    Hi, the Processes Table contains the following items for fastener installation amongst others:
    Power Tool <= 25.4 mm
    Power Tool <= 6.35 mm
    Power Tool > 25.4 mm
    Ratchet <= 25.4 mm
    Ratchet <= 6.35 mm
    Ratchet > 25.4 mm
    What does the dimension refer to? Diameter of the Bolt or the Bolt head? Diameter of the tool (bit, nut) used to install the fastener? Fastener Engagement Length?
    Regards, peterPan
    Power Tool &lt;= 25.4 mm
    Power Tool &lt;= 6.35 mm
    Power Tool &gt; 25.4 mm
    Ratchet &lt;= 25.4 mm
    Ratchet &lt;= 6.35 mm
    Ratchet &gt; 25.4 mm
    Regards, peterPan
    Question for $200: what's the "standard" way for specifying fastener size?
    Philippe
    Stress Engineer
    Technical Director 2007-2010
    Brakes, Steering & Drivetrain Lead 2007-2010
    Body Subteam Leader 2005-2007
    McGill Racing Team
    "Everything should be made as simple as possible, but not simpler." A. Einstein
    I agree that fastener size is specified by the diameter of the bolt but if you see here cost shouldn't matter by whether you are tightening a 6mm bolt or a 10mm bolt, rather it would depend on the engagement length. So I think we should use fastener engagement length.
    Deepak Singla
    Axlr8r Formula Racing
    IIT DELHI
