<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Chris_S:
Thanks for that. I have been using GSD and the Join/trim function for profiling the ends of the tubes, but it won't let me close the chassis. For example if I want to join the seatbelt bar to the roll hoop, you can only profile one end, as the seatbelt bar becomes part of the rollhoop on the first operation. </div></BLOCKQUOTE>
Hi Chris,
i knew this problem from our LR06. We designed the frame in one Part as well. At that time we solved the problem by duplicating every tube several times and using only these doubles in the Boolean operations. Today i would suggest to use paste special with result as link instead of paste. In 2006 it took us several hours to change a wall thnickness.
I hope it helps.
