We are looking at re-doing our outer wheel flanges for the 08 year.
Need some help from you guys as to what the most common bolt pattern and stud size is right now.
Scotty
Taylor Race Engineering
Scotty
Was kind of an oddball last year.. 3 x 65mm, with I believe .500" dia pins. Will likely be a little bigger pattern this coming year.
We do custom centers anyway. Or at least I hope they do again.
Colorado FSAE | '05 - '07
NASCAR Engineer | '11 - ??
4 x 3.75" bolt pattern to fit the wheels, and 12mm studs so we can use ARPs.
Scotty,
Call Wade at Kiezer wheel. He supplies most of the wheels and would have the best consensus of numbers on what to build flanges to.
Rob
4X100mm with 12mm studs
we run 3 x 3/8" on a 64mm pcd
Monash FSAE (2005-2009)
www.monashmotorsport.com
4 x 100mm 3/8-24 studs
Mike D
UTSA 04-
