I am working on designing a collapsible steering column. I basically have a cylinder that the steering column can slide into, which is preloaded with a spring that you would need to basically get into a crash to match the preload limit and start compressing the spring.
I think that ideally you would want to reach the end of the stroke of your mechanism (ie full spring compression) at about the point where a typical person's arm would break. This sounds kind of violent, but I think it is the safest design you can have since as you use up your travel you basically do not have a collapsible mechanism anymore and if the arm is broken from bottoming out the mechanism it would have broke long before that if the mechanism wasn't there.
My question: I am trying to figure out what the break strength of a human arm is. The bones in the forearm seem like they are the limiting factors (Radius and Ulna), although it wouldn't surprise me if it was actually the wrist or hand, but I couldn't even figure out how to analyse that (before anybody suggests it... real world testing is a horrible idea in this case. I think these bones are typically about 3/4" in diameter and in all my internet searching it looks like bones compression strength is around 22ksi. (this assumes around a 20-30year old male)
http://jap.physiology.org/cgi/content/abstract/10/3/493
I got a compression limit of 9000/bone or 18000lbs/arm or 36000lbs for 2 arms! This seams way too high to me. Does anybody have any experience trying to design a safety system like this? Maybe there is an industry standard that is way different than the way I am doing it.
