Hi,
Does anyone have references on brake pedal load?
I'm designing our brake system and we always used 150 lbs as load. But I heard someone, don't remember who, talking about a load increase of ~= 100 lbs/ g...
Is anyone heard off it??
Hi,
Adam Fecteau
FSAE Université Laval
Hi,
Adam Fecteau
150lbs is quite a bit....
Conor Riordan
Lincoln Design Judge 2013
Michigan Design Judge 2012, 2014
Notre Dame 2009
WMU Team Captain 2008
Brake pedal load can be whatever you want it to be. If you're not sure about the 100 lbs/g quote then go to a gym and use a leg press machine. Press 100 lbs with your left leg and ask yourself if that's a reasonable effort for 1 g.
If your brake system is already designed then calculated the required force at the pedal based on your braking system parameters.
You also have to consider your pedal ergo. Most cars in the FSAE comp have a flat leg driver postion. This being the legs of the driver are almost laying flat on the floor of the car. At this point you arent braking with you whole leg. It is mainly your ankle and calf muscle. I would say no more than 100lbs at full lockup. 75 would be better.
Have an idea of your brake line pressures? Hopefully someone should, then figure out the pedal ratio and you can figure out the load exerted by the driver to attain the pressure (for a given master cylinder size, etc...) simple fluids and statics. If you are designing from the ground up, figure out what pressures you want in the brake calipers, then the size of masters, and then define your pedal ratio to what you want to exert.
2003-2008 UF FSAE
I'm working on 300N/g (~60lb/g) pedal force gain.
You might want to look at:
NHTSA pdeal force gain data, Gillepsie, Fundamentals of Vehicle Dynamics, SAE, ISBN 1-56091-199-9, pp74
And also the velocity-time data published courtesy of Honda/Leeds Uni/Oxford Brookes which will show typical accel and decel around the track for an FS car. Linearise it all, calculate the decelerations, throw in a pedal force gain and out will pop your brake pedal pressure during typical brakign manouvres, average this, find out what your drivers like to see as an average brakign decel (or better still, I'd love to see data as to how well they can control brake pressure at different loads for a given seating position), then do your goal-seek to choose pedal ratio.
Sanity check it by reverse engineering a few established designs and seeing where they ended up?
Marko
Thanks markocosic for the ref.
Be sure I'll take a good look
Adam
Adam Fecteau
I'd think you want it as light as possible, balanced against the inevitable compliances working against you. That is, if you can lock the tires with, oh, 50lbs, wouldn't that be a better deal? How about 30lbs? Even better. The trouble's going to be the compliances of all the brake components using up your pedal stroke. Until I got rid of caliper flex in my Mini, I had to use a larger master cylinder just so I wouldn't use up all the pedal travel. Now, with rigid calipers and a hard pedal, I was able to go to a smaller master cylinder and got the pedal pressure way down.
Tube-frame, carbon composite-shell, Honda-powered, mid-engine Mini: www.kimini.com.
Buy my book: How to design and build a mid-engine sports car - from scratch. http://www.kimini.com/book_info/
You basically want a hard firm pedal with minimal movement because your brain finds that easy to control. As far as pedal pressures are concered, can you stand on your toes on one leg? If you can, your ankle/calf can handle pedal pressures equivalent to your weight, at least.
Brian
