Results 1 to 10 of 17
Thread: Gear Control Unit
    Hi,
    I am designing a Gearbox Control unit for your car, I am using a micro-controller and electro-penoumatic valves, a pinball air tank and a pneumatic ram.
    I got my system working ok but it is not great!
    Currently I am running a spark cut for 15ms any thoughts on this time??? (I read in some SAE paper that the minimum time for the gears to become disengaged is 100ms, surely that is an awful lot, F1 gear change is 50ms)
    Currently aiming to get the all shift done in under 80ms (The SMG in a BMW E46 M3 can do that time) ...
    Am I being too Optimistic??
    Probably not. Could be really difficult without being able to use auto throttle blips. Be careful not to ram any gears around. The gearbox wouldn't last long, though. Remember that F1 gearboxes only have to last 5 or so races and that they cost something like 80+ grand.
    Victoria FTW
    Can you elaborate on what "is not great" means? That could mean any number of things.
    UCONN FSAE: Old Guy #2
    www.facebook.com/uconnfsae
    An F1 gear box compared to an FSAE gear box is apple to oranges. And 15ms may work on a dyno but I can tell you with near certainty that will not work on the road. Typically what we see in the AMA super bike program is around 50ms.
    One thing you may want to mull over is power reinstatement. Will you have the ignition come back on in full all at once so you have 100% torque again? Maybe be you could look in to adding the ignition back in degrees per engine cycle. Think about how it affects the chassis if you have all the power hit the tires again right after a shift.I know its not something normally mentioned around here but like I said just something to think about.
    Alex Weissinger
    ECU Systems Engineer
    Apex Speed Technology
    alex@apexspeedtech.com
    We use Motec for controlling the shift and clutch solenoids. A 100ms cut is required for the 1-2 shift, but the 4-5 shift only needs a 30ms cut. But that's what works for us. The speed of your shift system, and your engine and transmission will all affect what you need for your setup. Solenoids from even the same manufacturer will vary in their activation speeds, and piston speeds will be affected by your pneumatic setup, for example.
    around 40% success rate in shifting
    Modena, Italy
    362
    I think your targets are a bit optimistic. What is your logic for applying force? Timed pulse?
    Sounds like the shift is not strong enough or held for long enough. Ive seen many times people finding the shift force by loading up the shifting lever with weights until it shifts, and then calling that the shift force. Then they wonder why their actuator wont shift.
    To get a good fast shift, you need a pretty brutal actuator.
    A hint, the cut time should be the last thing to optimise. You cant set the cut time, until you know how long the shift actually takes! In anycase, start at 500ms and work your way down. If it doesnt work at 500ms, then the hardware needs a rethink.
    Tim
    Jan 2009
    Stuttgart
    494
    Well 500ms is quite pessimistic. But 15ms is definitely too optimistic. Try it with longer ignition cuts.
    In lap times there isn't such a big difference if it takes a couple of ms longer until you got power at the wheels again. But if your driver never can be sure, if the gearbox really shifted that will cost you quite a lot of time.
    And as mentioned before actuation force really shouldn't be too careful. Gearbox actuation is designed quite robust at most motorbike engines as they should last a while and some drivers hit the lever really hard.
    Rennteam Uni Stuttgart
    2008: Seat and Bodywork
    2009: Team captain
    GreenTeam Uni Stuttgart
    Formula Student Austria
    2012: Operative Team
    Yeah but the acceleration event...
    Tim
    I doubt that we suffer with force (250N+), the problem was the pneumatic ram it took a massive 150~200ms to fully extend even at 180psi (its rated at 120psi)
    We changed it to an voice coil actuator and got the actuator to push the leaver up in 80ms the whole shift is done in 100ms...
    I am quite happy about it, tomorrow we are going to do some dynamic testing
