plastic tube can get pretty unhealthy too.
when PVC gets hot it releases chlorine gas. that's some pretty nasty stuff too.
but welding is a lot easier with hot glue, it's a lot like MIG.
There are a couple problem areas you will need to address. The main roll hoop tube can't be welded and has minimum bend radii. The upper side impact bar has maximum and minimum height restrictions. You guys should take a good look at the rule book because it will save you a lot of headaches in the long run.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TG:
There are a couple problem areas you will need to address. The main roll hoop tube can't be welded and has minimum bend radii. The upper side impact bar has maximum and minimum height restrictions. You guys should take a good look at the rule book because it will save you a lot of headaches in the long run. </div></BLOCKQUOTE>
Thanks for the help TG! I think we'll probably just bring several sets of different sized casters with us so that we don't get hung up on any height restrictions in tech.
man how I miss all the fun of FSAE
Micah McMahan
Red Bull Powertrains Performance Design Team Leader
3MI Racing LLC Owner/Engineer
Former MSI Defense Solutions - Sr. Design Engineer/Project Manager
Former Roush Yates Engines - Sr. Design & Analysis Engineer
ODU FSAE 04 member, 05 controls leader, 06 control/ergo/brakes leader, 07 brakes/MC22 turbo engine/Asst Team Leader
