Results 1 to 5 of 5
Thread: torsen differential required
    hello guys, this is aious racing team from india .we have tried to contact torsen company many a times . but they are not responding .we are midway through the construction of our car and we urgently need a reasonably new lsd differential
    aious racing team india
    <pre class="ip-ubbcode-code-pre"> www.aious.in </pre> www.aious.in
    Pat, Possibly a dumb question, as I am new to suspension, but when tuning rear slip angles with a solid rear axle, can you achieve the same, or close to the same turning power as with double wishbones and a spool? I am just starting to look at our tyre data, and any advice for this setup would be appreciated!
    Also, we are running Hoosier 20-6x10's, which appear to be only mildly camber sensitive. This is why I would assume that we can get nearly the response out of the tyres, without having to worry about the laden wheel cambering out.
    JR
    J.R.
    University at Buffalo Alum.
    Safety Wire Team Leader
    "Most of the things worth doing in the world had been declared impossible before they were done."
    Louis D. Brandeis
    JR,
    Absolutely!
    A fantastic demonstration was when the University of Queensland car smoked the field in the Dynamic events at FSG 2006.
    This car was a fairly standard spaceframe car with A arm and pushrod suspension.
    Once one gets their head around the differential slip angles required and how to generate them, these cars work very well.
    Not only that, but it's a good way to take some significant mass out of the car and a significant cost saving.
    Something well worth investigating.
    A word of warning. If you turn up at the comp with a spool, you better have some good reasons why, because the Judges will really grill you!
    Search the archives here. There have been several pertinant posts by the original UQ team.
