Hi,
I have searched on the forum and in the cost report appendix but have found nothing.
I was wondering the appropriate use of the "Hand - Start only" process.
My understanding is that is only needed when we put a bolt or nut in place by hand before using another tool. But when using a screwdriver/socket ratchet or other tools that does not need the fastener already sitting on the threads we would not need it.
I have missed the point?
In a second order,
We use the Mill Form - Cutter process to make splines, we were wondering if the length needs to represent the process.
For exemple, we have a steel shaft with 24 x 2.15 cm splines.
We are costing
51.6cm
x 0.10$/cm (Mill Form-cutter)
x 3 (Steel multiplier)
it adds up to 15.48$ which seems pretty pricey. Is that alright.
Thank you,
