@jpusb,
yes, i correct the corner radius for each output point of the diagram. Actually, since it is a constant velocity simulation, calculating the Fy gives automatically an Ay, so the radius is defined automatically as an output. From there i also then derive the slip angles.
By the way, here below the results i got for the three different TLLTD scenarios. I will add another message with the diagrams corresponding to the same scenario.
