Can you hear the difference between a V8 and a V6? Between a V6 and a four banger? Now the difference between a four banger and a 2cyl? I'd hope so, especially if you're the "engine and turbo guy" at cornell. You know what? Go out to your car, unplug 2 spark plug wires, and tell me you can't hear a difference.Originally posted by VFR750R:
Do you think the judges would notice if you cut two cylinders (4 cylinder engines only)at the point of MAP and RPM you see during sound test? It is pretty far out on the map, you would almost never see that on the track...and if you did, you obviously had your foot at something less then WOT.
Everything sounds like a V8, the only difference is the number of beats it's either missing or adding.
