Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Single rear brake on Drexler LSD
  1. #11
    Can be done. We replaced our diffs' splined end with a non-splined one (like the right-side endcap), because it wasn't needed (we do not use a chain drive as the diff is placed inside the electric motor assembly...)
  2. #12
    Feb 2011
    North Carolina
    114
    The only problem I have with this is a single brake being used on a car with a LSD. Unless I'm missing something here. -_-
    Trent Strunk
    University of Kansas
    Jayhawk Motorsports
    2010-2014
    Now in NASCAR land. Boogity.
    Opinions Are My Own
  3. #13
    Jul 2009
    Starkville, MS
    299
    It really depends on the type of LSD and whether it is a problem. For a Torsen type, as long as you don't pick up a wheel it should work ok ( same thing applies if you pick up a wheel and hit the gas pedal). For a Clutch pack type, it should work regardless since the clutches are helping you out.
    --Dash Robinson
    --Mississippi State University
