Hello All I'm new to this forum but have been doing some extensive research on raising the CR of our engine which is a 600f4i. I've done some reading on high compression pistons. Is there a piston most people use? JE? Wiseco? Also by using a high compression piston does that increase overall volume of the engine? Is there a piston that increases the CR while staying under the 610cc limit? What kind of CR can we expect from such a piston?
