Originally posted by Christopher Catto:
I think you've got enough there to keep your FE package busy for a while.
ERW I believe is not suitable for an FIA cage but check the rules (i forget). You can fab uprights and stuff with ERW box section but dunno about parts of the chassis...
CDS commonly used in many forms of racing, reasonably good!
For FSAE U will not save wt in the main and front rollhopp by using better steel since rules mandate a certain thickness.
I would go for T-45 for the chassis but it's expensive. See if you can find the stuff before doing FE unless u're doing it just for a project.
Chromoly used by many teams also
1020 is the cheapest if your team is starting from scratch. Chassis will cost peanuts and will be about 2-3kg heavier but depends really...
Dunno much about DOM, but maybe I know it under a different name.
