I was hoping I could get some feedback from some of you on the relationship between motion ratio and wheel travel, and what you feel is ideal. I understand that rising motion ratios can cause undesirable oversteer/understeer effects from pitch movements during corner entry and exit. It seems like decreasing rates would be beneficial in corner entry/exit scenario, but that the response in bump and roll would not be adequate. As such I have decided to design towards as constant as possible, keeping in mind that rising rate would be better than decreasing rate.
I have been trying to finalize a new set of bellcrank plates to improve upon some that were done a few months ago. I have been using a combination of SolidWorks, Excel and Susprog3D to generate the graphs shown below.
On the graphs below, (-) corresponds to droop, while (+) corresponds to bump. Design is for 1.250" droop, 1.75" bump in which 0.5" is the bump stop. I choose to do the analysis between 1.25" droop and 1.5" bump.
Graph 1 shows a sinusoidal type relationship, but if you look at the scale you can see that the wheel rate only changes by ~ 2.5 lb/in. My only concern with this relationship is its sensitivity to the inputs (coilover mount, bellcrank geometry), otherwise I feel it would act as a constant rate.
Graph 2 & 3 show rising rate motion ratios with graph 2 gaining ~ 6 lb/in and graph 3 gaining ~ 10 lb/in.
Any feedback would be greatly appreciated!
Graph 1
Graph 2
Graph 3
