hi just want to ask about ABS...are they allowed???
Only if you align the master cylinder with Orion's belt.
Gian Flavio Violi B.
Technical Support & Projects Manager - ARCUS Technologies CA [SolidWorks VAR]
Suspension Joe 2009-2011
Technical Director 2011-2012
F-SAE Universidad Simón Bolívar Team - Carcas - Venezuela
Yes they are, but you have to check back with the organizers/rules responsibles from the respective event to suit their safety requirements.
Regards,
Tobias
Regards,
Tobias
Formula Student Germany
FSE Rules & Organisation
http://twitter.com/TobiasMic
http://TobiasMic.Blogspot.com
thankz very much indeed...sure i'd but one thing which i dont understand is that with ABS how are v going to LOCK all 4 wheels during the brake test???
Most racing ABS systems have a disable switch.
Exactly.
At FSG for example you have to do the brake test twice:
At the first time with de-activated ABS to show that your brakes are able to lock wheels.
The second time with activated ABS to show that it works in general.
Regards,
Tobias
Regards,
Tobias
o i got that now...thanks very much again...
Hi to all i just wanted to ask that has it ever happened that by mistake the ABS was applied automatically means (malfunctioning.)
How do you define malfunction?
If you only have an ABS function in place then it is only able to lower the brake pressure and not apply brake pressure (that would be ESP).
The worst failure in this case is probably that the valves stay open and no pressure is left in the system. In this case it would be necessary to de-activate the power supply since the valves are usually built in a normally-closed way. We coupled the power-supply of the ABS with the Cockpit-Mounted Master Switch for that reason.
We never had such a failure though, but we were/are using an industrial proven ABS with modified firmware which de-activates itself whenever something seems to be wrong with the setup/sensors etc.
Regards,
Tobias
Regards,
Tobias
Toby,
Don't get hooked by the spambots!
Pat
