Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: 2004 Aussie comp static events review
    Folks,
    We're putting together a few notes on the 04 Aussie comp to talk about at the follow-up review meeting, before everyone forgets how it all went down.
    The whole comp ran extremely well, but we got thrown a few curveballs - namely in the design and cost events, which weren't run how we expected them to be. The strict marking guideline for design judging was a little unexpected, but I actually preferred the way the cost event was run, compared to how the letter of the rules say... it was probably a better test of what we're meant to get out of this competition than getting asked things from a list.
    How did everyone else go with the static events? Anyone care to pass comment on how discussion with judges went during the design event? All comments welcome, it'd be nice to know how it ran for everyone else...
    ok, in the "cost discussion"
    they didn't ask about the (rehearsed answers) parts listed in the rules
    and the design judges were a bit random
    some didn't seem to know what they were looking at
    our marking sheet suggested we performed poorly on our engine score because
    cfd on your radiator shroud not done?
    logging oil pressure not done?
    4.03 second acceleration run, finished both endures without a hint of restart problems..
    makes you wonder....
    for the benefit of the chassis judges...
    next year we will bring a chassis torsional stiffness rig to the comp
    there'll be a cad model supplied before the comp
    all teams will need to do is supply 4 small steel plates about 250 * 250 * 6mm
    and bring dumb shocks
    for that matter, why dosn't the design judging get serious
    i'd make it mandatory
    tech inspection first
    weigh in
    cg test (during tilt test)
    dyno run (inertial correction run)
    ALL BEFORE JUDGING BEGAN
    (and i'd include that if you can't do the above tests, you don't get judged)
    We got some interesting comments in the design marking sheet too, but no cfd on the radiator shroud is a bit tough.
    If the design event was run with all those tests, the judges would have a great idea of a very small part of the entire package. It's like assessing a picasso by noting the presence of black and blue paint.
    To do things properly (inertia of everything that moves, shock performance, suspension geometry, brake consistency, engine drivability, and so on...) isn't practical, but all of these things will reflect in your dynamic event performance. At the very least, I think there should be a design final judged after the completion of all dynamic events, with your performance in the dynamic events fair game for discussion with judges.
    suspension geometry can be visuallised by those who know what they are looking at
    and yes damper performance needs a dyno, but anyone can bring their own damer dyno results
    the above are NOT able to be determined visually, and they are very important metrics
    for suspension judging I suggest each team has to fill out a set spreadsheet, that describes the static behavior of their car
    since >95% of cars run double wishbone, with push/pull rods, and four springs, or a monoshock.. these would suffice
    cars with other suspensions could devise their own comparative spreadsheet
    http://www.uq.edu.au/fsae/suspension/four_springs.xls
    http://www.uq.edu.au/fsae/suspension..._monoshock.xls
    http://www.uq.edu.au/fsae/suspension/rear_monoshock.xls
    for example our car has 4 springs and a front (drivers adjustable) ARB
    ours would look like this
    http://www.uq.edu.au/fsae/suspension/uq.xls
    regards
    (mr pants down) Frank
    i agree Frank, if these 4 tests could be conducted on every car, then the cars can be directly compared, at least eliminate some of the 'optimistic' dyno and chassis test results that we see. With only 20-30 cars at the Aus comp, if every team got organised we could have these tests completed on thursday, getting a dyno would be the only tricky part, but i'm sure something could be arranged without a great deal of hassle. Perhaps if Pat is watching he could put in a few ideas? Any other teams with opinions on this? I think at least autocross should be run before completion of design finals.
    Jarrod Hammond
    Monash University FSAE
    'optimistic' , that's one way to describe the situation
    Yeah i could see it a bit of a nightmare in the US comp, but the aussie comp would be easy
    open the place Thursday morning first thing, and most will have scrutinizing, brake, noise, tilt, and measurements done.
    presentation and cost on Friday morning, and design on Friday afternoon (for the stragglers to have a last chance making it through scruit and measurement)
    just make sure the test are (relatively) repeatable
    and i agree, design finals saturday night
    I'm sure the guys at Dyno Dynamics would jump at the chance to support fsae. Plenty of Uni's have purchased DD dynos
    Hope your test rig is stiff enough for a real carbon tub.
    Someone mention my name????
    Its difficult for me to comment about Design Judging as I am a senior design judge in the US and the UK. Although I see what Frank is getting at, I doubt it will happen.
    I too was somewhat disappointed at some aspects of design judging this year, however, most of the previous years gremlins had been exorcised.
    Next year, with improvements learned from this year it will be perfect
    I would like to see the preliminary judging select cars for a final, based on all the usual parameters. These would go to a final, where the slate woul;d be wiped clean, and a single group of judges, comprising the leader of each design crew and the specialists like Ron T, Peter G and even Claude R. if we can have him, judge the winners on Saturday night. No team should qualify for the finals in judging if they have not started in at least one dynamic event. In the case of a team getting chosen as a finalist, but unable to start in dynamics, including the Enduro on Sunday, they simply go to 'best of the rest' who didn't make the design finals. This would mean that design results might not be final until lunchtime Sunday.
    At the US event, a Dyno sheet is required for all finalists to enable proper powertrain judging. As Half Assed ( ) has suggested, it would be great to have the guys from Dyno Dynamics come help us.
    Regards to all, I hope Santa is kind and I wish you all a Happy Christmas/Hanukah or whatever else is appropriate at this time of year.
    Pat
    PS, Tokyo Denki did get their car running, albeit 2 weeks late. They can be seen testing at this address http://www.tdu-card.jp/projects/fsae.../041219_sh.wmv
    Pat
    Pat,
    Our feedback on the design judging will no doubt support changing to that sort of arrangement. Another thing that'd be nice is if the all-star judging team gave a guest lecture before the comp, like in 2003. That worked pretty well...
    Frank,
    If teams are 'optimistic' about test results, the design judges should be of the experience and calibre to call them on it. Tall stories tend to not stand up to educated scrutiny, so all the event organisers need to do to solve this is provide the educated scrutiny. In any case, all teams should be armed with extensive test results and supporting knowledge for the design event, and each should be just as important as the other in the judge's eyes. Having said that, an on-site dyno and associated glory prize would certainly add something to the competition.
    Perhaps the resources that would have been used measuring torsional stiffness and CG etc could be put towards organising another dynamic event ... like a 3 lap sprint event on the autocross track, preceding the single lap event. Track and surface specific setup would be possible, and it'd give the teams a better shot at achieving their best one lap time. Just an idea...
    I think the biggest problem with that plan, Frank, is the volunteers and officials you would need for an extra day. sae-a struggled to get enough to run the enduro on sunday. I don't see how you would get an extra day in the schedule.
    On the design and cost judging more people with experience in fsae and motorsport should be the judges, some don't have as good an understanding of the competition as is needed. This has improved a lot over the last couple of years but it can keep improving. I think a design final is a must though.
    Frank i don't know much about the powertrain side of things but not logging oil pressure is pretty silly. Just cause it seems to be working fine doesn't mean there isn't a problem.
