I have some questions for frequent users of Ansys Workbench. I typically use Ansys Classic for my analyses, however, I am switching over to Ansys Workbench and am having difficulties achieving the same results.
I've modeled my frame in Solidworks with suspension and various mounting brackets and exported the assembly as an IGES file (Manifold Solid B-Rep Object, Type 186). The exported IGES file contains only a 3D line sketch of the frame and the mounting brackets as Solids floating in their relative places.
I have imported the file into an Ansys Workbench geometry file where it generated Line Bodies for the 3D line sketch and the Solids Bodies for the mounting brackets. I have assigned appropriate cross section attributes to each line-body in the Geometry File and have meshed the elements in the Simulation File.
This is where I have problems.
1) When I apply loads and constraints, it appears that all the individual beams are floating in space and will deform independently from the other beam members, as if nothing was connected. I have seen other beam analyses where the frame was merged into one single part, however I get an error when I try to solve the Solution that says "An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present...". I will try to verify that my model is correct, but I can't seem to avoid getting this error.
2) Connections/Contacts. I cannot make any contacts or joint connections between the mounting brackets and the line-body beam elements. The Connection tool won't let me select lines or line bodies. Any suggestions?
3) Driver weight. I wanted to add a Point Mass to simulate the inertial forces of the driver sitting inside the vehicle, however, the Point Mass Feature seems to only apply to faces, whereas I have mentioned before, I only have line-bodies for the frame. Any ideas on how I can apply these loads? I suppose I could model a seat as a surface but that leads me back to Problem #2 where I can't seem to make any connections between line-bodies and anything else.
Any suggestions would be much appreciated.
Thanks,
Adam
