Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 32 of 32
Thread: Cutting out at high rpm
  1. #31
    Hi,
    We think we may have fixed it.
    The problem appeared to be that the sensing element of the sensor was too large pick up only a single tooth.
    Therefore the rising edge of one tooth would be cancelled out by the falling edge of another producing a rather odd waveform, and also reducing the amplitude of the majority of the signal (all apart from the missing teeth area).
    What we had been looking for in the waveform was more the symptom rather than the cause. Another team at FSG told us that they had similar issues and fixed the problem by making the end of the stock sensor smaller by machining it down to about 1mm wide. Thanks to the guys at CAT Racing!
    We're not certain its worked yet; a track test is needed yet to be sure, but it revved freely to 14000 rpm on the stands even with quick throttle application. We haven't been able to do that for a while....Fingers Crossed.
    Brunel Racing
    2010-2011 Rookie Machinist
    2011-2012 Primary Machinist and Problem Finder/Solver
    2012-2013 Composites Manufacturing and Problem Finder/Solver
  2. #32
    Great to hear!! You may also consider a 36 tooth wheel, which bosch also supports, or some of their other sensors. That way its not band-aided by a machined sensor which may impact reliability, or be sensitive to sensor rotation, or not be the same if you have to replace the sensor.
    Quote Originally Posted by Gareth Gwilliam View Post
    Hi,
    'engine and turbo guy'
    Cornell 02-03
