Hello everyone,
I think i am now technically half dead so i will try to keep this brief just so that i can get some sleep.
We are using the Honda CBR600RR 2008 California edition engine with the Performance Electronics Edge ECU (PE3).
We have started the engine using the stock ECU with no problems, and with the PE ECU, We have added in our intake system and started the engine with no problem, We have used the stock Exhaust as the one we manufactured had some critical errors which prevented us from using it and we decided the stock exhaust would be the faster solution.
Till now the engine, with the intake, stock exhaust and ECU have been running with no problems, up to today.
Yesterday While filling in the fuel tank some fuel splashed on the Harness which short circuited it and we had to disassemble it and trace it, we did that and fixed it and started the engine today after several attempts.
after starting the engine we noticed some smoke coming out from the exhaust so we turned it off and started it again, same problem and also the exhaust tubes coming from cylinders 1 and 2 are way too hot (near getting red hot) after no more than a minute of operation while the exhaust tubes from cylinders 3 and 4 are very cool that we can wrap our hands around them. The smoke is also appearing from exhaust tubes from cylinders 1 and 2 and not 3 and 4. Another noticeable feature was that the engine RPM and noise changed radically after starting it and the RPM reached nearly 4500RPM (idle at 2000 normally) with no one operating the throttle, We fixed that by lowering the air/Fuel ratio from the ECU and everything was back to normal except for the smoke and exhaust tube temperatures of cylinders 1 and 2.
We have checked the injectors' signal and all seem to be working, spark plug signals are also working, We even swapped the spark plugs between cylinders 1,2 and 3,4 and cylinders 1 and 2 still produced smoke and their exhaust tubes are flaming hot. We disassembled the exhaust from the engine and everything looks good on it, but the ports from cylinders 1 and 2 are very dry and ports 3 and 4 have some fuel in them.
Another clue is that the water temperature was changing quite quickly in comparison to our previous runs, and even after turning off the engine the water temperature increases by nearly 10 degrees F before starting to cool down.
We have tested nearly everything from the electronics side and everything we looked at is OK, We checked the spark plugs and injectors and they are OK as well.
We are now officially out of ideas and the only thing left for us is to disassemble the cylinder head and check if anything is wrong inside. We reckon the problem is not Cylinders 3 and 4 being cool but more cylinders 1 and 2 getting way hotter than they should be (in nearly a 30 seconds operation you would expect the exhaust tubes to be cool enough to touch), We suspect that maybe something is broken inside the engine (or maybe even a piece of plastic slipped in while we were assembling the intake or something) or the engine was hit while we were transferring it from the lab and a gasket is shifted from place. We really are guessing here as everything tested is working well. I personally suspect that cylinders 1 and 2 may not be getting enough fuel from the injectors and i am thinking of having another look at them but all seems to be well.
The only thing that we have changed from our previous times was the bolt in the water drain on the cylinder side and i think we replaced it with a longer bolt which we suspect is blocking the coolant flow to cylinders 1 and 2 which would explain the smoke and exhaust tubes over heating.
Anyone has any guesses as to what may be the problem or has anyone ran into a similar situation?
That was not brief i guess
