If you had the resources and the time, what type on engine would you design and build for the competition, would you use forced induction, and what would be your first choice for transmission? The Current top engine/transmission layout is just a four cylinder bike engine and the transmission that came with it, but as far as the ideal layout goes, it's pretty poor (high center of gravity and such).
Personally, I think an over square flat six turbo coupled to a custom five speed sequential transaxle would be my choice.
Easy to Balance and SMOOTH
Low center of gravity
Enough cylinders to avoid most of the pulsing effects
Short crankcase
Turbo to widen the power band (adds weight though and at high rpm it doesn't help as the air can't pass through the restrictor fast enough anyway... hmmm, maybe a bypass for high rpm...)
The only current custom engine I know of is the V8 by UWW (also what got me thinking about engines). I have to say, hats off to you guys - very impressive. I wish we had the facilities here at UVic to take on such an ambitious project. But who knows... maybe in 10 or 15 years a custom engine will be needed to stay competitive.
Comments?
