Anyone had any luck fitting spherical bearings to Fox Vanilla shocks? Most I've spoken to have said it can't be done.
Cheers,
Geoff Pearson
RMIT FSAE 2003
Cheers,
Geoff Pearson
RMIT FSAE 2003
Geoff Pearson
RMIT FSAE 02-04
Monash FSAE 05
RMIT FSAE 06-07
Yes, it can be done. Just did mine a few months back. Had to turn down the OD of the bearing a bit. Didn't want to bore out the shock ends since one end is really thin already. Had to build a small cylindrical clamp (centre pin to make sure bearing and clamp is concentric) to hold the outer race tight so that the whole thing can be turned on a lathe.
Saw UTA's 2002 car at SCCA's Solo 2 Nationals, they run spherical bearings on their Vanillas also.
Joe
Thanks for that Joe, most appreciated.
Cheers
Geoff
Geoff Pearson
RMIT FSAE 2003
Geoff Pearson
RMIT FSAE 02-04
Monash FSAE 05
RMIT FSAE 06-07
We also used spherical bearings in Fox Vanilla RCs last year, that worked out pretty well. I believe we even found bearings in the correct size to just press in, but I don't remember the size or the company at the moment.
Eric Wort
UIUC Formula SAE
Eric Wort
ex-UIUC Formula SAE member
aurora makes spherical bearings to fit the Fox vanilla's perfectly. just press them in. you can call them up and ask them for the part numbers. make sure that you know the specs of the shock eyes before you call.
www.formularpi.com
2003 Formula Student Runner-Up
