Thanks for the kind words guys.
MCoach,
There really isn't anything different between a 'diffuser' and a wing - all the principles remain the same. Airfoils also have a 'diffusing' section which is designed to recover pressure as quickly as possible without stalling. An undertray (which has a diffusing section) on a car just differs in that it doesn't have an aerodynamic top section, and it also has to deal with a lot more turbulent/messy air than a typical wing.
Moop,
The ground and the speed of the on coming air isn't really the whole story. Picture it like this, the car is traveling at 100km/h with no ambient wind, so using the car as the reference frame the road is moving under the car at 100 km/h, same as the on coming air. What happens underneath the front wing? The air is accelerated above 100 km/h. We now have a velocity gradient between the road and the air, this develops a kind of boundary layer.
Generally this symmetry/streamline assumption is used in wind tunnels without a rolling road to simulate ground effect. We tried this a few years ago..
Essentially you just build a mirror image of the front wing/undertray, then connect one of them to a force balance (or pressure tap it like we did^). The middle streamline between the two bodies is supposed to represent the ground - it does this far better than a non moving floor, but is still not completely accurate, due to the reasons above.
Haha yeah, aerodynamics is full of 'chicken or the egg' type problems. Did the curved streamlines create the pressure gradient, or did the pressure gradient curve the streamlines... One of the more ridiculous explanations of lift involves packets of air traveling along the top and bottom of the wing mysteriously having to meet up at the same time at the trailing edge...
There is nothing wrong with just sticking a big sheet of aluminum under your car and manually bending up an inlet or diffuser.. Then just drive different radius circles and record times. Alternatively you can fit soft springs and shock pots to measure displacement vs. velocity (beware varying ride heights though). Maybe play around with different diffuser angles? Agricultural but it will tell you if it works or not. If you can show that this was the best use of your time/resources design judges should not mark you down for that.
We actually do the different radius circles to figure out our 'effective' CL.A and CD.A, which takes into account load sensitivity and extra tyre drag due to aero.
Luke.
