Banning and i have been discussin' a bit of a different idea in the downforce ideas.
after the fluid lecture in spinning cylinders, if you refer to a handout with 6 pictures of flow around a cylinder, you will notice how much influence it has on the flow.
Now imagine a cylinder as a wing which is driven by the motor (remembering that engine power doesn't seem like a problem, wheelspin is always happenin)
This cylinder can spin at high revs and cause a (apparently wicked) down.
Weve spoken to Kelso about it, he says someone did this with a car.... some time ago.
And also didnt dismiss the idea....
He says a flat bar spinning is much more effective than the cylinder, BUT creates a shitload of drag.
Sooooooo...... the crux of the story is we can do such a down idea, But lots of drag will occur. Once again a trade off!!!!!! Just remember power doesn't seem to be a problem. If we can keep the straight line speed in the corners with a crap load of down, then all will be good as the tracks are so tight.
