So I have been searching for some time about dry sump systems. There is a lot of good information out there, but one problem I keep running into is that most of the comments are at least 3 years old if not 6. Many of the pictures don't show up in the threads any longer and, and the product lines have changed. Most of the links are also no longer valid.
So I will pose a few questions. First off, how are you running your pump? Off the water pump shaft with an external water pump? Any pictures would be helpful.
Another question would be, how many scavenge pickups are you running out of your oil pan. Is a 3 stage pump only good for 2 pickups for scavenging and 1 for crankcase pressurization?
Any change in products out there? I've seen pace and dailey engineering. Pace seems to have some problems with availability, maybe?
Are you machining your oil pans or welding them?
We will be running a cbr f4i again this year, and have been using a carbon fiber oil pan with no baffeling up to this point. We had never had a car running long enough to see the effects of oil starvation (which I believe we are occasionally seeing).
thanks
poe
