In that case, nothing in racing is.Originally posted by michaelwaltrip:
Short answer: Dry sumps are not worth the time/effort/weight/complexity when a simple trap-door style oil pan works great for this application.
Good racing is a matter of millimeters and milliseconds. Maybe it isn't good for some teams, but I'm sure with enough improvements in other areas, going to a dry sump would be your best improvement. Plus, once you get the system designed the first time, it's fairly easy to recycle year after year.
Our pan's a half inch thick. Without frame tabs, the pan bolts are the lowest point on the car. That makes the single heaviest component (besides driver of course) several inches lower. I know our suspension guy appreciates it.
~2g has no effect on our oil pressure. Lots of logs to back it up. The pressure vs. rpm histogram line is so well defined it's hard to make out the individual points. Looks like a nice, solid line.~2g has minimal effect on oil pressure.
In the end, if you think a dry sump is the best place to invest your efforts, or if you're just damn interested in doing one (this is a learning competition after all) then go for it. I'm all for them. However, when you say something like "We had never had a car running long enough to see the effects of oil starvation" it makes me think that just getting a car running and testing would be time better spent.
