Results 1 to 2 of 2
Thread: FS: KAZ/Penske 7800 DA Dampers and Comprehensive Anciliaries
    Pictured:
    • 7800 series double adjustable dampers from KAZ (75mm displacement variant)
    • 4x damper rebuild kits
    • 4x Digressive Pistons (never installed)
    • Comprehensive valving/shim kits (no shims used)
    • 8x spare Aurora spherical bearings for 7800 DA damper eyes (circlips included)
    • 4x Upgraded hollow steel damper shafts (never installed) for 75mm variants
    Associated manual/drawings/CAD models for reference: https://www.kaztechnologies.com/down...ustable-shock/
    Pricing:
    • 4x 7800 DA Dampers (75mm), rebuild kits (the o-rings/seals), and spherical bearing set - $1100
    • Valving/Shim Kits (everything in yellow boxes) - $800
    • Set of 4 unused digressive pistons - $450
    • Set of 4 Hollow Steel Upgraded Damper Shafts - $150
    All Sold - payment pending
