Please apply via: https://www.recruitacommunity.com/sr...=5000411998910
Through its people and brands, CNH Industrial delivers power, technology and innovation to farmers, builders and drivers all around the world. Each of its brands, including Case IH, New Holland Agriculture, Case and New Holland Construction, FPT Industrial, Capital, and Parts & Service, is a major international force in its specific sector.
As a Driveline Test Technician, you will be responsible for the Assembly & Disassembly of both prototype and production axles, gearboxes and transmissions per Engineering Specification. You will be involved in the set-up, monitoring and teardown of driveline test stands used for physical evaluation of performance and durability of driveline components. You will work in a cross-functional environment; interfacing regularly with Test Engineering, Design Engineering, Materials Engineering in support of New Product Development as well as Current Product Problem Resolution.
Responsibilities include:
- Assembly & Disassembly per engineering specification of complex drivelines including gearboxes, axles and transmissions for Ag and Construction Equipment.
- Mechanical Set-up, Operation, and monitoring of driveline component and integrated vehicle systems tests in laboratory, track or field environments.
- Connect and verify instrumentation used for data acquisition on driveline tests. Collect data for analysis by test engineers.
- Interface with test engineers to clearly understand test requirements.
- Support determining if the component(s) / system(s) under evaluation are operating according to the intended Design criteria. Aiding in diagnosis of any problems to determine and implement corrective action.
- Follow lab test procedures and processes.
Required Qualifications
The qualified candidate will have experience with the following:
- Minimum of an Associate's Degree in a Technical Field with at least:
- Minimum of 1 year experience/knowledge with mechanical, hydraulic, and electrical systems.
- Ability to travel, including internationally; Less than 10%.
The preferred candidate will have experience with the following:
- Minimum of a Bachelor's Degree in Agricultural or Mechanical Engineering Technology or similar.
- Experience with the assembly of heavy machinery axles and transmissions.
- Ability to read and interpret technical engineering documents and assembly drawings.
- Ability to work within a team environment where responsibilities are routinely shifted to meet changing priorities.
- Ability to work independently and recognize issues that need to be escalated.
- Strong hands-on mechanical skills.
- Good interpersonal skills to communicate effectively in both the lab and in a cross discipline team environment.
- A Positive, Energetic, "Can-Do" attitude with a Strong Desire to work in the heavy machinery industry.
- Basic Microsoft Office skills (Word, Excel).
- Ability to conduct technical hands-on mechanical tasks with little supervision.
