first of all ; what i want to say next it just a discussion . When i read in learn and compete book i found this (there is a tolerance in size of tubes )
page (34)
what i want to ask about is What is the limit of tolerance ?; For example i know that the minimum dimension of side impact tubes are OD=25.4mm & thickness= 1.65mm
say i bought tubes that meet the minimum requirement dimension (25.4mm & 1.65mm) and after i cut it i found that the thickness of tube equal 1.5mm because of manufacturing process that mention in the
(learn and compete book ) and i weld that tubes in chassis Is that will cause the chassis to be eliminated form competition ??
I read that using tubes with thickness less than 1.2 mm is prohibited and cause the chassis to be eliminated from competition Is using tubes with wall thickness = 1.5 mm instead of 1.65 will have the same result
Or the judges will understand this and recognize it ??
