Hello,
I am Mohamed Aziz, the head of engine team in Cairo University Racing Team.
The engine we use is a single cylinder KTM 450 EXC engine. Our controller is MegaSquirt 3X with V3.57 board.
We were testing the car till it suddenly stopped. I tried to increase the amount of fuel injected till the engine started once or twice but the amount of fuel was too high compared to that values with which the engine ran before.
So, I disassembled the injector and made sure that every part is fine. This means that no hoses are clogged or bent in a way that chokes the flow.
Then, I assembled it again and the engine was fine for about one minute before it went crazy again and stopped.
I used the testing mode in TunerStudio program and it was obvious that the flow rate of the injector is lower than normal (I tested it before) and it is not a steady flow.
You can watch the test here: https://www.youtube.com/watch?v=rVEHO6WMZ0o
