Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
Thread: 2016 Formula SAE Michigan
  1. #21
    Based on what it takes to build a car that's actually about $10k, I am very skeptical of Stuttgart's cost.
    Tennessee Tech's car cost, I'm much less skeptical about. $5500, was it? That car was built for one reason, win cost. It had a carburated V twin Briggs and Straton, centrifugal clutch, 600 sprint car rear axle, wheel and drive assembly. It had no muffler, aluminum/ steel everything, American Racer tires, and still weighed about 600lbs.
    It also had aluminum front and rear aero. However, I've never seen a car that wanted to tip over at such low lateral accelerations.
  2. #22
    I heard the TTU car had an onboard pull start! Cool! Any vids?
    If TTU didn't skew the cost score so much, Stuttgart's score would have been worth about 15 points, instead of 8 (still not enough to change the outcome of this event)
  3. #23
    1,688
    Firstly, many thanks to Moy for his pics!
    Regarding Cost Event, this remains only second to Design in its unfathomableness.
    From my quick look at car specs;
    * Cheapest car, Tennessee Tech, had a Vee-twin (admittedly B&S), spaceframe, some "black&round" 13" tires, WITH aero, for ~$5.5K.
    * Most expensive car, US Air Force, had a 450cc-single, spaceframe, 10" Hoosiers, with NO aero (USAF???), for almost ~$32K.
    Huh?????
    A handy reference for car specs (but missing #3 Graz TechU?) is here;
    http://www.fsaeonline.com/content/20...vent_Guide.pdf
    Rather amusing/disappointing in these "engineering specifications" is the mixture of every conceivable dimensioning system. Yep, you name it, inches, millimetres, cubits?, kilograms, pounds, ... are all in there.
    It reminds me of the Mars Climate Orbiter of 1998. Google this mission and you find phrases like,
    "... project cost of around 1/3 billion dollars (~$1,000,000/kg of the spacecraft itself)...
    ... NASA using metric units in its system software...
    ...the MCO manufacturer, Lockheed Martin, using "pounds-force" in its software...
    ...intended orbital elevation of 226 km above Martian surface...
    ...minimum survivable elevation of ~80 km before atmospheric friction causes burn-up...
    ...time of "orbital insertion" rocket burn ... miscalculated...
    ...actual final elevation after rocket burn ... 57 km..."
    Guess the result!
    And the really funny bit,
    "...several days before orbital insertion some ground staff noticed the discrepancies between calculated and measured positions and advised a course correction, but...
    ... these suggestions were dismissed..."
    Will they ever learn?
    Well, you only have to go as far as the second entry in above Event Guide to find,
    "Univ of Florida
    Wheelbase: 2950 mm (61 in)."
  4. #24
    Maybe it is time for publicly available cost reports as well?
  5. #25
    Jan 2009
    Stuttgart
    494
    If you want to score well in cost, you need to understand how the cost event works, you don't need to build an actually cheap car ;-) The difficult task is to have all parts with all materials and all processes listed as it is much harder for the cost judges to check if your numbers are correct than to find parts which are just missing. Therefore the cost event never really worked to reward teams who build simple and therefore cheap to manufacture cars.
    Regarding GFRs weight. The just have less parts than most other cars in the field. Direct acting dampers, no ARBs, small engine without fancy stuff like adjustable runner length, no shitload of electronic gadgets. For me it's no surprise, there car is that lightweight. The bigger surprise is why their car is not much cheaper in cost than Stuttgart's ;-)
    Rennteam Uni Stuttgart
    2008: Seat and Bodywork
    2009: Team captain
    GreenTeam Uni Stuttgart
    Formula Student Austria
    2012: Operative Team
  6. #26
    Quote Originally Posted by Bemo View Post
    ...it is much harder for the cost judges to check if your numbers are correct than to find parts which are just missing.
    Having all the parts listed correctly, but with deflated costs for everything are not supposed to be how this event works. Let's not make it a race to the bottom.
  7. #27
    Feb 2011
    North Carolina
    114
    Quote Originally Posted by MCoach View Post
    Too late, that race has been happening for awhile now.
    Trent Strunk
    University of Kansas
    Jayhawk Motorsports
    2010-2014
    Now in NASCAR land. Boogity.
    Opinions Are My Own
  8. #28
    Quote Originally Posted by theTTshark View Post
    I'm well aware, but I can still stand my ground and insist this is not racing where "whatever it takes" is encouraged to get ahead.
    This is supposed to be an educational event to teach good practices and students to learn what it takes to efficiently balance their cost/performance envelope.
    In the real world, it is obvious that this type of creative accounting has been well rewarded, but leads to situations that companies land themselves into like Enron and Volkswagen.
    Fool me once, shame on you. Fool me again...
    https://www.youtube.com/watch?v=KjmjqlOPd6A
  9. #29
    GFR Performance
    Hi All,
    I'm sure that others have noted as well that GFR's overall 4th place is a pretty dramatic break with tradition for them.
    Ever since they started in 2010, they have (amazingly) won every endurance they managed to finish.
    (Equally impressive, they've won every single overall event whenever they finished the endurance)
    So for them to finish 7th in the endurance, almost 5 seconds a lap slower than TU Graz is a whole new experience.
    Any insights as to what happened here? GFR's previous car was on average 4,5 seconds a lap FASTER when racing the same TU Graz car in Germany last year.
    New drivers? The average lap times of the two drivers were very different, despite being quite similar at previous events.
    Or was something wrong with the car/simply not enough test kms?
    cheers,
    Thijs
    Alumnus
    Formula Student Team Delft
    2007 - 2008: Powertrain, Suspension
    2009: Technical Lead
    2010 - present: Grumpy Old Fart/Concerned Citizen
  10. #30
    This needs to change, along with efficiency scoring.
    UQ Racing
