Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: FSAE is Not a Kit Car Competition
  1. #21
    Modena, Italy
    363
    I don't think the issue is just the fact that off-the-shelf parts are used.
    The issue is when they are used like a backyard mechanic. I.e. slapped on without understanding a single thing about the part or it's application.
  2. #22
    Quote Originally Posted by Tim.Wright View Post
    Pardon, I was a little blunt. I agree with you. Do your own analysis, prove that it's the best way to reach your concept.
  3. #23
    If a team is buying parts to save time/resources I would be very surprised if they then dedicated the time required for a proper analysis, people always find a way to fill their schedules.
    Even if they do are they really learning as much? So yeah they may put up a better result that year, but are they really helping their program grow in the long run? (Haas disclaimer: This isnt F1 with huge prize money)
    I'm sure the average enrollment of engineers at most schools is >3000 students, surely the capacity is there to develop a 20-30 person team that is capable of building a chassis. In short, it will all come out in the wash one day..
  4. #24
    Quote Originally Posted by JT A. View Post
    This very quickly turns into a "where do you draw the line" argument.
    I fully agree with JT A. above. And the rest of his post. And with the many other posts along similar lines. And, yes, even with Tim's post!
    So... Where SHOULD the line be drawn?
    If this was a competition for "Trade School" students, then, sure, they reasonably could be allowed to use "Off-The-Shelf" designs/plans, but they SHOULD do all the hands-on machining/fabricating/welding of the component parts. Because that is what they are learning to do.
    But "Engineering" students are supposed to be learning things at a somewhat higher level. In short, in FS/FSAE they are supposed to be learning how to solve "the puzzle of scoring most points" under the given set of restrictions, which are mainly the Laws of Nature, but also the more fickle FS/FSAE Rules.
    Assuming this is true, then why does Claude have a bias against "Lego cars"?
    Could, in fact, something like Mitchell's recycled ATV/Quad-bike be the best "engineering" solution to the puzzle?
    For an inexperienced or low budget Team, I would say DEFINITELY YES!
    A Lego-ATV-car for FSAE is probably the easiest, quickest, and cheapest, way to THRASH at least half the other Teams in all the Dynamic events. Remember, all you need to do really well in Dynamics is "... a conveyance that can carry a single person a distance of 30 kms, at an average speed of ~55 kph". And such a car should also do really well in (a realistic...) Cost event. Which leaves only 15% of the total points subject to the biases of the Design Judges.
    Going a bit further, could a Lego-ATV-car, with perhaps a bit of "aero-engineering" thrown at it, be a globally dominating car?
    Of course! (Do I have to give a bigger hint ^ ? )
    And, pushing the envelope still further, could you use a bit more "engineering" to beat this already globally dominating car?
    IMO, sure! The two main areas to "engineer" are:
    1. The drivetrain needs reworking to better package all the big bits (mainly the driver + engine) for a more compact, lower total-mass, lower-Iz, car. This only requires design and manufacture of some shafts (maybe using OTS gears?), and some accurately enough machined boxes to put it all in. So you might need some of those trade school boys to help you with the tolerancing (or see Cole's post on same).
    2. MORE, AND BETTER, AERO! Best aero comes from the underbody, and the right size/shape aero-undertray for your car is unlikely to be found on Ebay. And the aero-flows around the upper-body also have to be done right, so as to properly drive the underflows, so this requires whole-car thinking.
    So, some good engineering can turn a dirt-cheap Lego-ATV-car into a world beater. But...
    What about Claude's insistance that students "engineer" the hubs/uprights/suspension, IA, etc.?
    Fact is that none of these parts has a huge influence on making the car faster. But badly done, they surely cripple the car's chance of scoring well (eg. bad IA = DNS, bad hub/axle/wheel-bearings/++ = DNF)!
    In other words, these critical items are NOT the things that good Engineers would take big risks with, say, by getting inexperienced students to "optimise" the design. Especially when the "optimisation" is backed up by inadequate (non-existent?) testing.
    By analogy, the Rules mandate all critical fasteners to be of a minimum standard. The Rules do not allow these critical items to be student machined parts...
    So, what is left is a puzzle with 15% of it subject to the many and varied irrational biases of Design Judges.
    Claude has his pet likes of the suspension bits, even though these do little to make the car faster, or cheaper. Other DJs want all FSAE engines to be tyre-shredding, horsepower monsters, and they penalize Teams that focus on economy and reliability.
    All of which, IMO, is good reason to get rid of such irrational, UN-engineering-like, biases.
    Ditch the DJs (and Design Event), and let the stopwatch, together with a realistic Cost Event, do the judging.
  5. #25
    I think a major issue is whether the 'kit car' teams can (or do) score highly in the competition overall.
    A perfectly legal strategy for FSAE is to ignore the Design event (and the associated effort), build a fast car out of off-the-shelf parts and score highly enough in the dynamic events to do well overall. That would upset many who hold the Design event close to their hearts.
    The next questions are: How probable is it that this could happen? How would it affect the student's education? Should the competition scoring be altered to eliminate this possibility?
    Plenty of debate here, I feel.
    Regards, Ian
  6. #26
    This discussion falls under two different aspects, engineering and competition. For obvious reasons, a fully designed, manufactured, tested, correlated car will net the most engineering experience. But engineering is really problem solving, and the #1 metric at competition is points. Until there is a points advantage for using all custom designed parts, why wouldn't you buy off the shelf parts, such as the steering rack? Design of the rack would involve 1 or 2 members to dedicate a significant amount of time determining stiffness goals, designing parts, manufacturing, testing, and so on. Some teams don't have this ability.
    What if they could only cost parts "as made" if they actually make it? The zRack is $1200, but can be costed at much much cheaper. You get the best of both worlds, a stiff lightweight steering rack, that gains you points in dynamics, but doesn't cost you any more in the cost event. If this put a big $1200 addition to the cost report, I'm sure teams would consider machining their own.
    I agree that all parts on the car need backed up with data. You must explain that the zRack meets stiffness and weight goals, fits in the team budget, packages nicely, has the desired ratio. You must also explain that designing/manufacturing one from scratch would take about 80 hours and cost $500 to meet the same stiffness/weight targets. Then explain how the points/cost/time trade-off works into the team project management and engineering.
    Adam
    Any views or opinions expressed by me may in no way reflect those of Kettering University, it's students and administrators, or our sponsors.
  7. #27
    Lutz,
    I do not have a problem with the impact attenuator. But I do have a problem with people who do buy one and the engineering design and test report ....without understating it.
    Claude
  8. #28
    I still remember back in 2011 when we dropped a huge box filled with junk on our impact attenuator to validate it.
    Scary.
    Daniel Schwind
    UFF - Universidade Federal Fluminense (Rio de Janeiro, Brazil)
    2015 - Mechanical Systems Leader - Faraday Racing Formula SAE-E
    2014 - Powertrain Consultant - Buffalo Formula SAE-C
    2013 - Powertrain Leader - Buffalo Formula SAE-C
    2012 - Brake System Co-Designer - Buffalo Formula SAE-C
    2011 - Newbie/Do everything - Buffalo Formula SAE-C
  9. #29
    Oh yes. There's a reason the procedure I wrote for it said that the strap used to pull the quick-release hook lever had to be 20' long and that the person pulling the strap needed a straight unobstructed path out the door.
    Charles Kaneb
    Magna International
  10. #30
    Lutz,
    Claude, while from an educational stand I think it's great for teams to understand why they are doing things. But from a problem solving, time and resource management approach (which is ultimately what we're trying to educate these students for) it doesn't make much sense.
    If the teams spend all of their time analysing every single rule and the reasoning behind why the exact values and limitation were picked, they'd never get round to actually doing any design work, and they'd never get to the end of it without actually asking the person who came up with rule, exactly what calculation were done to decide why the roll hoop must have 2.6mm wall thickness, etc. So as soon as a team makes, what is for them, the correct decision to use the standard IA to better allocate resources elsewhere, why spend any more time thinking about it, that undermines the whole reason for picking it in the first place? Either you trust the rule makers to know that it is a good, safe design, or you shouldn't be making a car to any of the other rules either!
    If a team gets to design judging and says they only had 5 team members, a $5000 budget, only one lathe and mill and no CNC. But they can justify, mainly through: man-hours available<man-hours estimated to design and build, that off the shelf parts were the only way they had of getting a car built in time to get 3 months of rigorous testing done during which time they pushed the car to it's absolute limits, and can prove it on track.
    THEN another team turns up with:
    50+ members, $100,000+ budget, a workshop full of facilities including CNC machining, and a sponsor with an autoclave for their carbon chassis and full aero package, and can also justify all their designs through lengthy calculations and simulations that their hordes of team members did. And also got there car running in time for 3 months of testing (by paying to have all their parts custom made by someone else, and getting their hordes of team members to make them).
    If both cars look reliable enough, and have evidence of their testing, but no evidence of direct comparison lap times, then I would assume that the second car was probably faster. BUT considering they had 10x more team members, 20x more money, and lets say 10x more facilities, and their car cannot be 2000 (=10x20x10) times faster, then the first team has done a far more efficient job than the second. Okay the 2000x isn't a usable number for comparison due to diminishing returns on performance gains, but the point is made.
    Dunk
    Brunel Racing
