Hi guys, I'm making some simulations with matlab to understand vehicle dynamics using a simple bicycle model.
It requires to know some vehicle parameters.
One of these is cornering stiffness.
I have calculated it using this formula from Pacejka's tyre model (96) using data from TTC:
Since it is a 2 dof model, with no pitch motion, I used a static weight for Fz (no load transfer).
I assumed the same value for front (Cf) and rear (Cr) cornering stiffness.
I found a lot of data in which there are different values for Cf and Cr.
Here is an example:
I don't know by what criteria I can state to have different value for the front and the rear.
I would like to know your opinion.
Are my assumptions reasonable? Have you any suggestions?
I also tried to compare linear tyre model with Pacejka's one.
I made a Matlab script but linear model seems to be not tangent to Pacejka's curve for lateral force.
Here is the script I'm using
https://www.dropbox.com/s/1quqpgym2s...ar_fsae.m?dl=0
